And the next problem is.........
Post by e3steve » Thu Jan 15, 2009 5:07 pm
Look for voltage on the back of the combo switch inside the headlamp, terminal 'BAT' (red wire).
If yes, then turn the key on and check terminal 'IG' (light green/red); if no, check the 15A fise near the battery +ve post.
EDIT: IG wires are black and black with a white sleeve! Lt gn/red is neutral lamp switch wire.
slopokecr
Post by slopokecr » Thu Jan 15, 2009 9:20 pm
Deep Breath.
Thanks Taylor and Steve for your responses.
I am just starting to get my head around this electrical stuff, and unfortunately, your diagrams and acronyms and shorthand are greek to me. BUT fortunately I have a patient friend who will be helping me who does understand the language. Until I can get my friend over, im gonna keep trying.
Steve, can you tell me if I have cracked your code language correctly. I assume that the "combo switch" you speak of is the one that the key goes in? And 'terminal BAT' is the battery terminal with the red wire?
Also, the only green wire coming out of the 'combo' switch is all green and seems to go to handlebar (horn and highbeam?) I dont have a "light grn/red" wire. (does your slash(/) mean "and" or "or")
Thanks for your patience.
-Kent
slopokecr
Post by slopokecr » Thu Jan 15, 2009 9:21 pm
Deep Breath.
-Kent
slopokecr
Post by slopokecr » Thu Jan 15, 2009 10:22 pm
ok, found wiring diagram and it helps crack the code
Post by e3steve » Sat Jan 17, 2009 5:48 am
Sorry chum, lt grn/red means a base colour of light green with a red tracer (sometimes called a binary or secondary colour or stripe). I can't find my wiring diagrams, as I'm in the process of moving apartment, but I think the ignition circuit wire on a C/CA is lt grn/r; I've posted both CB and CA digrams on the forum before now, so I'll look back.
Initially you're looking for voltage at the combination switch (ignition/light switch) on the terminal marked BAT or with a red mark. It should have a red wire from the battery and via the 15-Amp fuse. Using a logical process of elimination, if you have voltage there but not at terminal IG (ignition) with the key 'on', then the combo switch may be faulty; if you have NO voltage at BAT, then the fuse close to the +ve (positive) battery terminal has probably blown or is intermittently discontinuous due to corrosion or a bad connection.
Off you go.....
EDIT: Sorry, hold that wire colour! That's the neutral lamp wire from the neutral switch. Christ knows where I got that from, as I know that's the colour for neutral on a CB! I should have known better....
The IG(nition) wire colours are black and black with a white sleeve.
http://www.honda305.com/forums/download.php?id=379
Post by e3steve » Sat Jan 17, 2009 6:10 am
Ignition switch wiring & terminals should be as follows:
Term BA, battery, red
Term HL, headlamp switch, green
Term TL, parking lights, white
Term IG, (ignition system) & key-on circuit, black & black with white sleeve
Term CH, charging from rectifier (celenium diode pack) white/red
EDIT: this is a CB keyswitch; here's the Touring models' combo switch:
Term BAT, battery, red
Term DY, dynamo (links to SE for lights-on boost), pink
Term SE, rectifier (links to DY for lights-on boost), yellow
Term ML, meter lamp, brown
Term TL, parking lights, blk/y
Term ST, starter solenoid feed, blk/red
slopokecr
Post by slopokecr » Sat Jan 17, 2009 6:19 pm
thanks a Bunch steve!
Ive learned a pile in the last few days.
Found the problem--was a bad connection at the black/red connector that goes into the combo switch. The wiring diagram does not match up exactly with what i have, so I wonder if switch was replaced previously.
-Kent
