Swing arm bolt
Re: What bike is my swing arm bolt off of?
Post by LOUD MOUSE » Wed Apr 08, 2009 7:07 pm
Have a parts book for your bike?. ..................lm
Adam Tucker wrote:Sorry this is a bit off subject, but I wondering what model 305's used a swing arm bolt which had oil zerks on both ends of the bolt. I first realized that I didn't have the correct bolt for my 67 Cl77, when the nut for the bolt barely caught 2 threads. I did get the correct bolt for my bike off ebay, but I am curious as to which model years used the shorter double zerked bolt.
Thanks
Adam
Adam Tucker
Post by Adam Tucker » Thu Apr 09, 2009 4:47 pm
Unfortunately, I do not. Have you ever run into this kind of bolt?
Post by LOUD MOUSE » Thu Apr 09, 2009 5:41 pm
If it's a normal 1966/67 CL77 I have the correct bolt. ...........lm
Adam Tucker wrote:Unfortunately, I do not. Have you ever run into this kind of bolt?
RIDE IT DON'T HIDE IT!
Post by e3steve » Fri Apr 10, 2009 2:46 am
e3steve wrote:Well, well, well; my rear axle nut's on the right, too. And I'd never noticed!
Now, if I'd read the Post Subject header correctly, I'd have noticed that it's titled "Swing arm bolt", so why I decided to make a 'metric conversion' into "Rear axle bolt" is just infathomable!
When I got my CB I was unable to correct the rear brake cable's sharp exit from the right footpeg support for the same reason stated in Lee's opening post. If the swing arm bolt is installed from the left, therefore placing the nut on the right, then the r/h peg angle cannot be placed at the proper detent.
Adam Tucker
Post by Adam Tucker » Fri Apr 10, 2009 11:00 am
If I am understanding correctly, you are saying that the earlier (pre 66) Cl77's used the the shorter double zerked swing arm bolt? Did the CL72 also use this bolt?
Thanks for the info,
Adam
Post by LOUD MOUSE » Fri Apr 10, 2009 11:13 am
The CL72 used the bolt which had the rear brake cable "receiver" (end holder) screwed into the left end. The CL77 had that end of the cable fitted at a lug welded to the frame tube. .............lm
Adam Tucker wrote:If I am understanding correctly, you are saying that the earlier (pre 66) Cl77's used the the shorter double zerked swing arm bolt? Did the CL72 also use this bolt?
Adam
