Page 2 of 3
Posted: Tue Jun 01, 2010 3:05 pm
by Wilf
I'm thinking it would be adequate. I swapped out the original rectifier on my 1963 CB77 for an over the counter silicon bridge replacement meeting/exceeding the previously quoted specs and everything seems fine so far.
My turn signals and brake/tail light are LED, which draw way less current, but I don't think that would make a difference in your charging circuit.
Wilf
Posted: Tue Jun 01, 2010 10:56 pm
by Gunner_CAF
I bought a replacement rectifier from Retro Bikes that looks the same as the original but with upgraded diodes. No fabrication needed.
Gunner[/u]
Posted: Wed Jun 02, 2010 1:56 am
by e3steve
Eljeef wrote:Wilf wrote:Eljeef,
The Radio Shack rectifiers (276-1185) are getting hard to find in Canada, but any bridge rectifier that meets or exceeds the specs (PIV of 50 volts or more, and Forward Current of 25 amps or more) will work just as well.
Wilf
Wilf, would that be adequate for a Dream with all the turn signals? Jeff H.
A 25A rectifier is perfect. After all, the entire electrical system is fused at 15A. A 25A rec will run cooler than a 15A and a 40A will offer slightly more attenuation to the resultant output, so I'd recommend a 25A.
Topic after
topic after
topic to follow.
Posted: Wed Jun 02, 2010 7:56 pm
by Eljeef
Well I crossed the border last night and picked up the Radio Shack rectifier, heck for just over $3 I grabbed two. I also took a heat sink out of an obsolete computer at work today. I'll try to hook it up tomorrow. Cheers. Jeff H.
Posted: Thu Jun 03, 2010 8:54 am
by Dr. Frankenstein
Eljeef, do you have a pic of that rectifier, and any info on installing it? Is it simply a 'plug-N-play'??
-John
Posted: Wed Jun 23, 2010 6:54 pm
by Eljeef
Dr. Frankenstein wrote:Eljeef, do you have a pic of that rectifier, and any info on installing it? Is it simply a 'plug-N-play'??
-John
Geez, I should check this more often. Sorry for the delay John. I don't have a picture of the Radio Shack rectifier but search this forum under rectifier or just follow this link to Brewsky's post
http://www.honda305.com/forum/index.htm Good Luck :)
Posted: Mon Jun 28, 2010 12:48 am
by Eljeef
O.K. Let's see if I can get this project moving again. Finally ended the electrolysis process on my fuel tank. Here's a blurry photo;
Anyway, I ran it through electrolysis about six times (only because I left it so long between treatments a little rust would form ). I dropped a handful of lockwashers and nuts in the tank and shook it every which way for awhile to get any remaining crust off, then I rinsed it out with fresh water, then rinsed again with Isopropyl alcohol, then again with varsol. I hope that will do. I also installed my new rectifier from Retro Bikes. It looks preety great I must say.
I have moved the two black cables to a position underneath the rectifier where I believe they are supposed to be. I also patched up some exposed wires near the grommet. Cheers.
