Replacement float valves
flathead
Post by flathead » Thu Oct 21, 2010 2:01 pm
Davo,
I got the brass tube from McMaster-Carr. Mine was a BCH smaller than the hole, so I had to expand it by wiggling the shank of a #45 drill in the end till I got a tight fit. Worked great.
Saved 3 unusable bowls.
Mark
Post by davomoto » Thu Oct 21, 2010 7:16 pm
In technical terms, correct me if I'm wrong, a BCH is .0001mm larger than an RCH. :-)
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Post by e3steve » Fri Oct 22, 2010 3:05 am
Ah, but both are pretty coarse measurements compared to a GCH......
Snakeoil
Post by Snakeoil » Fri Oct 22, 2010 10:07 am
Thanks for the feedback. As a former machinist, CH dimensions are known to me, plus I have a conversion chart on the wall should I forget.
Mine is not leaking at the carbs. Both my carbs dribble a small amount of gas out the overflow tubes that are connected to the brass overflow tubes. It leaves two marks on the ground under the bike. So that is why I think it is the worn float needles. And I know they are worn. Actually, probably the most worn of any valves I've seen in all my years of tinkering with engines.
I checked to make sure the floats were free, but the point about the gaskets extruding into the bowl, which was mentioned in another post I found with a search, might be playing a role here. I'm in the process of going thru some maintenance items on the engine now that the riding season is coming to a close so I'll recheck those carb floats for free travel.
Thanks for the tip on CB750F viton tipped float valves.
regards,
Rob
wargoth
Post by wargoth » Fri Nov 05, 2010 10:02 am
I want a copy of the CH chart, could you post a pic?
'61 CB77, '72 TC125, '72 CB350F, '73 CB350G, '76 CB400T, '79 XR80, '79 XS750 (850), '83 CB650S, '84 KDX250,'91 YZ 250
