Location to find code to replace key?????
mike1969
ignition switch
Post by mike1969 » Thu Nov 11, 2010 1:13 am
Can you post a picture of your switch and key?
sky1haze
Post by sky1haze » Thu Nov 11, 2010 11:05 am
I'm sorry, I don't know how to resize my pic to fit......
It is the original ignition, I am the second owner.Its a 1966, It has been garaged its whole life, just about 5,ooo miles on it.
I took the ignition out to look about. I found a code: 6QL11E
Does this make sense?????
-joel-
_______________________________________
1966 CA77
Hahnda
Post by Hahnda » Thu Nov 11, 2010 11:19 am
The number should be on the face of the ignition switch. Right next to where you put the key in.
Does the old key work? Does the old key have NA266 stamped on it? Does the new key look like the old key?
mike1969
key
Post by mike1969 » Thu Nov 11, 2010 12:25 pm
You can post a picture temporarily in the classifieds without having to re-size.
Sounds like someone may have changed the switch at one time and used one from a different bike.
Hard to say without pics.
sky1haze
Post by sky1haze » Thu Nov 11, 2010 6:03 pm
everything everyone made sense....I just learnes that the ignition was changed while it was sitting in the garage for the next user because the original owner lost the key..................I find this out today after all the research..... It is a honda "T" shaped key marked 11E
No one seems to have a blank.......I have a key, it is fragile....bummer.
-joel-
1966 CA77
Post by e3steve » Fri Nov 12, 2010 1:36 pm
Pic, Joel? Whole key and then the end (the pointy bit) so that we can see the flute profiles.
nc_rider
Post by nc_rider » Sun Dec 26, 2010 1:10 pm
It looks like I have two different tumblers for my ignition and steering lock.. .
ignition has T4644 stamped on it
steering lock has NA820 stamped on it
"DL" key that fits the ignition has 67LC stamped on it
smaller "DL" key that fits ignition (but has side grooves that are different from larger key) has HD26 stamped on it
With a gentle little wiggling I can get basically any small key partially into the steering lock and turn it.
What's the best route here? Try to get another key to match the steering lock? Can either ignition or steering lock be rekeyed so they match?
And.. did CA77s ship from factory with matching ignition and steering locks? (so a PO of this bike swapped the ignition switch at some point long, long ago)
