Woody
You're in a much better position to find the answer to that question than I am......
I rarely perform miracles, let alone at 3000 miles away.... :-)
You're going to have to look inside my friend.
4th gear not there
I finally got the time to look in to my problem and discovered that I have a 13 tooth front drive sprocket which had me revved up so high going down the road that I thought I wasn't getting out of third gear. Can anyone tell me what the correct size forward drive sprocket I should be running on this 1966 305 scrambler? I know it has the shallow splines. Also what size sprocket belongs on the back? Anyone know where to locate these sprockets? I have read that the shallow forward sprockets are hard to find. Thanks Woody
A 15 tooth front and as you have a CL77 a 37 rear.
I may have the front. ............lm
woodrow wrote:I finally got the time to look in to my problem and discovered that I have a 13 tooth front drive sprocket which had me revved up so high going down the road that I thought I wasn't getting out of third gear. Can anyone tell me what the correct size forward drive sprocket I should be running on this 1966 305 scrambler? I know it has the shallow splines. Also what size sprocket belongs on the back? Anyone know where to locate these sprockets? I have read that the shallow forward sprockets are hard to find. Thanks Woody
http://www.ebay.com/itm/Nos-HONDA-41201 ... f0&vxp=mtr
http://www.ebay.com/itm/Honda-Late-CL77 ... 0e&vxp=mtr
http://www.ebay.com/itm/Honda-Late-CL77 ... f2&vxp=mtr
Woody
Depending on what sprockets you can find to purchase, 17/40 will give you a slightly higher gearing than 15/37. 16/40 will get you near standard gearing with non standard sprockets.
17 / 40 = 0.425
16 / 40 = 0.400
15 / 37 = 0.405
17 / 40 = 0.425
16 / 40 = 0.400
15 / 37 = 0.405
