Just what IS in US fuel???
Post by LOUD MOUSE » Sun Jul 05, 2015 6:43 am
Keep an eye on it.
Vinegar will resolve the carb body if you leave it to long. .................lm
modelman wrote:OK, thanks for that, everything is now soaking in vinegar, watch this space!!!!!
Post by G-Man » Sun Jul 05, 2015 1:34 pm
LM sounds pretty sensible to me. I'll give the vinegar a try next time around.
Thanks
LOUD MOUSE wrote:This may be difficult for some to believe!
That stuff was caused by having WATER in therefor a LONG TIME.
If you find this stuff again Vinegar will remove it. ....................lm
modelman wrote:Well after soaking in the ultrasonic tank for many duty-cycles & at the hottest temp, (too hot to touch) the carbs have come up like new, revealing holes in the float-bowl, managed to remove all the brass screws, plugs, jets etc. EXCEPT the main? jet at the bottom of the lower hole in the pic above.
I don't think any of this stuff has ever been removed from new as all the brass hexagons, screw slots are perfect, with the body held secure, a good fitting screwdriver was applied, tapped, twisted with a vise-grip on the handle, but still no, I have the feeling that I'm close to shearing the top off.
Replacements seem to be like rocking-horse s**t,
SO, I think for the time being, a replacement set of carbs will be required, I've read on this forum that 26mm Amal concentrics can be used, would that be the bog-standard 'basic' handed units??
I see from the specs that they have 2" (50mm) flange-hole centres as against 48mm of the originals, I can mill these 1 mm each to 'adjust' the fitting.
Also, they seem a bit taller, any issues with that?
modelman
Post by modelman » Mon Jul 06, 2015 5:53 am
Ok, so they were soaked overnight in vinegar, this morning I dried them off, held securely in the vice, warmed (carefully) with the propane torch, A good fitting screwdriver, pushed hard down & they actually came out!!!
WAY-HAY !! I might not now require replacement carbs, they are lovely & clean from being in the ultrasonic tank for 2 days, new gaskets & seals ordered, only problem now is that I cant find replacement fuel bowls, so I'm wondering if they are abraded in my blast-cabinet if some form of liquid-metal is applied & if it will be fuel-tight??
Anyone had experience of doing this??
Thanks for the 'vinegar' tip, this old dog has just learned a new trick!!
Post by LOUD MOUSE » Mon Jul 06, 2015 7:13 am
You can JB WELD them or I can send a couple $12.00 US each plus mail to he UK. ............lm
modelman wrote:Ok, so they were soaked overnight in vinegar, this morning I dried them off, held securely in the vice, warmed (carefully) with the propane torch, A good fitting screwdriver, pushed hard down & they actually came out!!!
modelman
Post by modelman » Mon Jul 06, 2015 8:40 am
Thanks again, we have that locally, I'll go get some.
