Happens to the others also. ..........lm
G-Man wrote:Dianne
It's your bike but as a Mechanical Engineer for 35 years I would be interested in how the crack got there..... :-)
LOUD MOUSE wrote:At one time that bolt was not TIGHT.
G-Man wrote:Dianne
DianneB wrote:I also noticed that there is a bit more space between the engine case and the frame than I am happy with. If I was building it (the first time) I would have put a washer between the engine and the frame so that the frame wasn't under stress when the bolts are tight. It could have been that stress that caused the metal to fatigue in the narrowest part over the years. I will make the doubler of the appropriate thickness to fill that space.
That's the plan - pick up the engine bolt and extend the plate up the inside of the frame to pick up a doubler plate higher up. I haven't measured it yet but think the gap is about 0.080" so that will be the thickness of the doubler.G-Man wrote:Might be worth making a plate with a hole for the engine bolt and tacking that to the inside of the frame. It would spread the load a little better.
