What would you do?
modelman
- Contact:
Just bit-the -bullet & started to hack the replacements about, either that or I bin them!!
First pic is one fitted correctly using the bracket, & it looks cr*p.
https://www.dropbox.com/s/369drxe99989k ... 1.jpg?dl=0
Second pic, I cut a vee in the pipe, bent & had a couple of trial fits before welding, then had
to fabricate a new mounting-bracket, not finished yet, but I think it already looks better, it
won't suite the purists out there, but I don't care!!
https://www.dropbox.com/s/u13kp7nwysnru ... 2.jpg?dl=0
The hard bit is making the other side 'match' the angle & spacing! Ho-Hum.
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
Looking better already. As an alternative I would look at these.
https://www.feked.com/universal-mini-go ... -45mm.html
modelman wrote:Just bit-the -bullet & started to hack the replacements about, either that or I bin them!!
Geoff Hastings
modelman
- Contact:
Hi, Geoff,
thanks for kind comments, but the covers are not injection-molded, I 3D printed them, not
perfect, this is the 6th set i've done, all not right, & this is the latest effort, & they are more
or less there, having difficulty forming the lower front corner. I printed the knob as well! I might just 'tweak' the design & print more, but not in the mood right now!!
https://www.dropbox.com/s/veuwdo6wzkdxl ... r.jpg?dl=0
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
Geoff Hastings
modelman
- Contact:
Nothing i'm afraid, the covers I printed are plastic!!rrietman wrote:M; interesting, what can you tell me about metal/composite printing? I'm thinking about a brake plate for a CB92.unobtanium, but I have a good one for a pattern.
Randy
If I printed one from my machine it would last as long as a chocolate exhaust pipe!!
Seriously though, some years ago I needed a few alloy parts, not bike related, so I made wood plugs & prepared them, took them to a small, local foundry where they sand-cast them, maybe the same could be done from your pattern, but then machining will be required to complete.
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
