Drilling CL 72 crank for a stater clutch
Re: Drilling crank
Post by G-Man » Sun May 12, 2019 2:53 pm
You might be able to find someone in your area that specialises in Spark Erosion.
https://edmprecision.com/spark-eroding/
Kthomas55 wrote:I ordered bits from my local Fastenal. The just barely made a dent. They said the next price up was 30+ dollars apiece for a 2mm bit. I’m either going to try one more time by ordering some bits or buy another crank. These were cobalt bits.
Kthomas55
Drilling
Post by Kthomas55 » Fri May 17, 2019 7:45 am
I think I’m just going to get another crank. I’ve tried 8 different bits. Honda had some hard metal ! The last two bits I used were Artu’s which were recomended. On there site they describe the multi-purpose for hardened steel but I couldn’t find those in that small of a size. 2mm or 5/64. As you know buying cranks off line is a crapshoot .
Spark erosion would probably work but finding someone around here won’t be easy.
Tim Allman
Re: Drilling
Post by Tim Allman » Fri May 17, 2019 9:29 am
Kthomas55 wrote:I think I’m just going to get another crank. I’ve tried 8 different bits. Honda had some hard metal ! The last two bits I used were Artu’s which were recomended. On there site they describe the multi-purpose for hardened steel but I couldn’t find those in that small of a size. 2mm or 5/64. As you know buying cranks off line is a crapshoot .
I have a suggestion. Where I live one of the major industries is car and car parts production and to support this there are dozens of companies supplying the factories. I have found that by asking around I have been able to find things that would never be carried by a hardware store. Odd tools can be expensive(!) but they are often available.
Re: Drilling
Post by G-Man » Fri May 17, 2019 10:16 am
As a last suggestion - how about a diamond burr in a Dremel or similar. You may need the patience of a saiint but it should work.
https://www.ebay.com/itm/30pcs-Diamond- ... Sw2DdbMu33
Kthomas55
Post by Kthomas55 » Fri May 17, 2019 12:19 pm
That’s a great idea.
I thought about a burr on a Drexel but thought it would dull fairly quick. A diamond type burr might do it
Post by G-Man » Fri May 17, 2019 12:48 pm
You might need to build a little moat around the hole to contain some lubricant/coolant. Do you have plasticine in the US? That should work.
Kthomas55 wrote:That’s a great idea.
Post by LOUD MOUSE » Fri May 24, 2019 5:43 pm
Are you needing CB72 crank? ................. lm
