CM77E Cases
deuce_7
Re: CB77E Cases
Post by deuce_7 » Sun Jun 25, 2023 10:16 am
BowlingSS wrote:
Sun Jun 25, 2023 8:35 am
It is a CB77. Sorry.
Thanks for the clarification.
There are two 8mm studs rising vertically from the under crankcase and through the upper crankcase, secured by hex nuts in the upper crankcase well under the latched/removable upper crankcase cover. Loosen those hex nuts to be flush with the stud threads and tap-tap the studs. It may help the crankcase separating process.
1967 CL77 305 Scrambler
BowlingSS
Re: CB77E Cases
Post by BowlingSS » Sun Jun 25, 2023 10:19 am
Thanks I will give that a try.
Bill
1965 Honda CB77 Super Hawk
BowlingSS
Re: CM77E Cases
Post by BowlingSS » Mon Jun 26, 2023 5:55 pm
Finally got the cases apart. I used heat and a good rubber hammer.
Thanks everyone.
Bill
