Joel
Agreed, Rob. But it sounds as though the spindle is likely to be shagged anyway. At least the threads could be cleaned up with a file and/or junior hacksaw; and the nipple orifice reamed with a mousetail file or a 5(?)mm drill bit.Snakeoil wrote:My concern with using a steel rod or drift is you can mushroom the end of the pivot bolt and create yet more problems for yourself.
A thought I had last night was if you can get someone to help you and you have access to an impact wrench, either air or electric, put your assistant on the wrench and have him spin the bolt without putting any axial pressure on the bolt, while you smack it from the other end.
I do agree that a bigger hammer is better in this case. I still prefer you use an aluminum, brass or copper rod. If you know somebody in the phone company, they use copper grounding rods that are just gorgeous. If you can get one, there is enough there to make lots of copper drifts for moving stuff without damaging it.
regards,
Rob
