Reading valve color
nander
Has anyone encountered this problem -- where the starter motor becomes inadvertently bound to the crank?
e3steve, LM, anyone, please enlighten me: what other parts might there be to the story? I don't want to leave any stone unturned here.
Teazer what struck me about that white valve is that the valves I see in the other crusty heads I have are all carbonized. I looked elsewhere on automotive and motorcycle forums and it seems that light colored exhaust valves are common in some engines. However, from my own limited experience, I don't think it's the case for 305 motors.
nander
nander
- h305 Moderator
I've read several topics where the screws have backed out, that's all I can add really. The starter gearbox isn't wrecked, the chain is intact (otherwise you'd have stated otherwise); all that's left to test is the motor itself, and that should be just fine.nander wrote:Has anyone encountered this problem -- where the starter motor becomes inadvertently bound to the crank?
nander
I reckon you have little to worry over. If you need a starter sprocket, I have one somewhere. If yours isn't running true it'll show by scraping on the crankcases or on the little retainer. It may just cause an oil leak from not running properly on the lip seals if it's badly distorted, but that's unlikely and it's a piece of piss to change, even when to bike's fully re-assembled.
Don't panic (Mr Mainwaring! -- Dad's Army). These little bikes are as hard as nails, mate.
