Resurrection of a wreck
John Watson
Post by John Watson » Wed Jun 06, 2018 1:27 pm
There's nothing fresh showing, Geoff, did you receive my email address?
Post by G-Man » Wed Jun 06, 2018 3:25 pm
John
Let me know what you need. I'll be with my 'stash' of Dream parts tomorrow.
John Watson wrote: I'm making a list of stuff I'm still short of so if any of our members this side of the pond can help, I would be most grateful.
John Watson
Post by John Watson » Wed Jun 06, 2018 3:52 pm
Here goes, Graham;
RH siďe cover, both parts
Starter clutch
Air filter cover
Filter/carb trunking
Rear lamp assembly
Headlamp shroud and Honda badge
Footrest front and rear
Rear brake pedal
Thanks in advance.
Post by G-Man » Thu Jun 07, 2018 12:20 am
John
Here's what I 'know' I have. The other stuff I may have.
John Watson wrote:Here goes, Graham;
RH siďe cover, both parts .. Definitely the big cover with spring / knuckle / lifter etc
Starter clutch -- Yes
Air filter cover -- need to check
Filter/carb trunking -- eBay / DSS
Rear lamp assembly -- Depends what sort
Headlamp shroud and Honda badge --- Yes, both
Footrest front and rear -- rears yes
Rear brake pedal -- I'll say yes
Thanks in advance.
Geoff Hastings
Post by Geoff Hastings » Thu Jun 07, 2018 3:58 am
Sorry John, I miss understood what you meant by side cover. I was thinking the pressed steel cover that goes over the starter solenoid and electrical connections as it seemed to be missing on your original photo. Anyway, looks like Graham can sort you out, your project looks to be progressing well.
John Watson
Post by John Watson » Thu Jun 07, 2018 5:10 am
I've replied to your email, Geoff, you were correct in your initial assumption, I need both the aluminium genny and chain cover as well as your sheet steel item.
John Watson
Post by John Watson » Fri Jun 08, 2018 8:50 am
Why is there always one item that you need that always slips under the radar? Graham, if you have a gearbox cross shaft, the one that the gear change lever attaches to, could you add it to my list, please? If you haven't got one, if anyone else has, then I would be very grateful.
