1966 CB77 Restoration Project
Post by Seadog » Thu Apr 12, 2018 4:29 pm
G-Man wrote:Nice paint finish and good-looking kickstart bush.... :-)
Thank you, G. The bush is nice; that cover is going on the '66. The other parts are for the '64, which I want back on the road ASAP. The paint is the VHT brand that 48lesco recommended. It applied a bit differently than the Duplicolor I've used in the past and the results weren't quite as good. I think it's because it's still too cold here. I oven cured it (shh...the wife's away for a few days ;-)) ). It worked better today on the '64's starter motor, which will not be oven cured.
Crankshaft installation tomorrow.
Post by LOUD MOUSE » Thu Apr 12, 2018 8:29 pm
Any time ya need such a simple part let me know Terry. ...................lm
Seadog wrote:
LOUD MOUSE wrote:What part ya waiting for Terry?. ..................lm
A crank bearing locating pin. I thought I had all 4, but I must have lost one because I can’t find it. It must be with one of the rollers I lost for the kick start shaft bearing, which I had to replace. A new one for the crank bearing arrived in today’s mail.
Post by Seadog » Fri Apr 13, 2018 7:09 am
Thank you, LM, I will.
LOUD MOUSE wrote:Any time ya need such a simple part let me know Terry. ...................lm
Post by Seadog » Fri Apr 13, 2018 4:17 pm
The crankshaft went in this afternoon, but not without a bit of difficulty with the left (clutch side) bearing. It needed gentle persuasion. While spinning the crank after dropping it in, I noticed a bit of warble on the right side. Bent shaft?
Click on the picture for video:
Post by G-Man » Sat Apr 14, 2018 12:45 am
That looks pretty horrible. The 'runout' should be less than 1 thou (0.001) inch on the chank. Maybe yours has been dropped? Using it like that will result in vibration and premature failure.
If you have facilities and a good dead-blow hammer, you should be able to get it in line. The crank case will do as a place to do the truing. I think it more likely that the crank is out of line rather than the shaft bent.
To check for truth you need to pull off the outer bearings and put a dial gauge against the shaft.
Once you find where the misalignment is, you 'bump' the appropriate flywheel to move the shaft back in line. You need to be patient as it's possible to make it worse. It's like building a wheel, you quickly learn which way to go and how much of a whack you need to give it.
Here's my CB72 crank after truing.
Post by Seadog » Sat Apr 14, 2018 8:18 am
Thanks, G. I have not dropped the crank, but it has had a long life, so who knows what it's been through. I can't use it like that, so, as I have nothing to lose, I might give straightening it a try. I will, however, be on the lookout for a replacement which, as you know, would be a pig in a poke and I might end up as bad or worse off than I am now. Nothing is easy or straightforward with this project.
Post by G-Man » Sat Apr 14, 2018 8:48 am
Hi Seadog
Happy to talk you through the process and provide whatever help I can. First job is to take measurements to see what is out of line.
Seadog wrote:Thanks, G. I have not dropped the crank, but it has had a long life, so who knows what it's been through. I can't use it like that, so, as I have nothing to lose, I might give straightening it a try. I will, however, be on the lookout for a replacement which, as you know, would be a pig in a poke and I might end up as bad or worse off than I am now. Nothing is easy or straightforward with this project.
