1961 CB72 Project
Post by LOUD MOUSE » Sun Apr 30, 2017 9:05 am
Great pic.
Even the oil pump extension. ................lm
G-Man wrote:Today has been chilly but dry but I resolved to get a space cleared out to assemble engine and frame. The clear-out and reorganisation took so long that I was only able to get the engine loosely assembled in the frame and then wheel it into its new home fro firther work.
I can now statrt the search for all of the other parts that I carefully put away ready for the build. I used and old wheel to help me get her in the shed but, at least, the matching engine and frame are together again.
More tomorrow - hopefully wheel building.
Post by G-Man » Sun Apr 30, 2017 11:32 am
Ha !
I thought you would be the only one to notice that, LM.
I couldn't get the oil pump to seat nicely with it on. More investigation needed. Pretty sure this was the pump and filter that belongs to the engine but I might have some mismatched parts.
LOUD MOUSE wrote:Great pic.
https://goo.gl/images/Lk5xAm
Post by LOUD MOUSE » Sun Apr 30, 2017 11:39 am
Question.
Are you using the short filter or the later issue which allows MORE oil to the pump?. .................lm
G-Man wrote:Ha !
Post by G-Man » Sun Apr 30, 2017 12:04 pm
Good question. I'll check through th evarious parts I have. It looks like it only needs 3mm or so but I didn't want to force it.
LOUD MOUSE wrote:Question.
G-Man wrote:Ha !
[/quote]
Tim Allman
Post by Tim Allman » Sun Apr 30, 2017 12:37 pm
Please enlighten us about the oil filter details. This is new to me.
G-Man wrote:Good question. I'll check through th evarious parts I have. It looks like it only needs 3mm or so but I didn't want to force it.
G-Man wrote:Ha !
[/quote]
Post by LOUD MOUSE » Sun Apr 30, 2017 12:45 pm
The very early engines have a screen filter on the pump which didn't fit aginst the case at the top so HONDA placed a phenolic/plastic spacer there. (you can see the spacer on the grass)
The design change has a taller screen to allow more oil to the pump so there isn't room/need for the spacer. .....................lm
Tim Allman wrote:Please enlighten us about the oil filter details. This is new to me.
G-Man wrote:Ha !
[/quote]
Post by G-Man » Sun Apr 30, 2017 1:56 pm
Many thanks - LM
I managed to locate an early filter screen and a later (030) one.
Interesting that the manual shows the 'receiver' with the wide end at the top while my engine had it the other way up.
Do you know which is correct?
