I have found oil in the headlight bucket and I get an oil spay on my left leg from the tach cable I think. Is that possible? If so, perhaps a vital gasket is missing somewhere. Anybody have any data on what gaskets are in the cable itself. I have taken the cable off the engine and it seems to have a rubber gasket - not sure how oil is getting up the core of the cable though.
Thanks
Jack
Oil leak from Tach cable
Re: Oil leak from Tach cable
If you did find a rubber seal at the engine of the cable make sure it does fit/seal the cable end. If it's to large at the cable oil pressure from the case as the engine runs can fprce oil up the cable. Have you made sure the top vent hose is clear?. .............lm
sail121j wrote:I have found oil in the headlight bucket and I get an oil spay on my left leg from the tach cable I think. Is that possible? If so, perhaps a vital gasket is missing somewhere. Anybody have any data on what gaskets are in the cable itself. I have taken the cable off the engine and it seems to have a rubber gasket - not sure how oil is getting up the core of the cable though.
Thanks
Jack
Had the same problem with my CB72 and a black tach assy. Changed the to a new one (black). but still a lot of oil in the hedlight. Wanted to have a genuine grey one and found one on e-bay. On delivery I found out that the inner cable had a differnt length compared to the black assy. On the black assy, the cable does not induce enough sealing force on the seal.
So, if you have a black assy and the original was grey; get a grey one.
Oil from tach cable
Rode some 50 miles today and discoverd that I got oil comig out of the headlight housing. This despit that I got a grey cable, as I mentioned in the above reply from Mars 22:nd.
So, now I need help as well. I have checked the seal and it's fine (and new). Also the vent hose from the top is "breathing" fine.
Re: Oil from tach cable
Get a different tach drive. .........lm
Steven62 wrote:Rode some 50 miles today and discoverd that I got oil comig out of the headlight housing. This despit that I got a grey cable, as I mentioned in the above reply from Mars 22:nd.
Oil from Tach cable
Have tried 3 assys; the black one that was on the bike when I got it, the black one I bought here in Sweden and the grey one a found on e-bay (which is a newly made copy). All assys creates the same problem; oil i head light housing.
Now I have more closely checked the difference between the assys and found that the seal in the grey one was much smaller than in the black "original" ones. Have now transferd the seal from the black one to the grey assy. Will let you know if this solved the problem.
