Ok that was bad pun
I need a fork lock and key for my 1964 CA77.
Now how do a take out the old one?
And are all the fork locks the same as a C77 ect?
Thanks
Brad
Need a forken lock and key
- FluteTears
1974 CT90
1964 CA77
1964 CA77
- FluteTears
Well that is the problem the ignition has been switched out and I have tryed Honda Keys and got no reply from them. I think I will try them one more time but I never had a good key intell I replaced the ignition. the one that was in the bike when I got it worked with a screw driver.joeweir1 wrote:Do you have a ignition key for the one on the bike, you are aware the the lock and ign. are the same key?The fork lock pops out easily by using the key.Just a alittle twist and turn and it pops out.You can get keys made.HondaKeys.com has them.I think the C77 are the same.
I wonder if I should drill out the old one.
Thanks for the info on the C77 I will look into that.
Anyone drill one out?
Brad
1974 CT90
1964 CA77
1964 CA77
- FluteTears
Been a month now sence I ask about a key.joeweir1 wrote:I would not be in a big hurry to drill it out.I recently e-mailed Hondakeys and it did take acouple of days for a reply, but they were helpful.They should have the key you need.Good luck.
I will try them one more time.
Thanks
Brad
1974 CT90
1964 CA77
1964 CA77
- FluteTears
Well I had checked with LM first but I am going to post the Key# anyway maybe I will get lucky and some one will have one or two.davomoto wrote:Brad, what is the # on the lock? I have some old T series keys, and I think LM has some of the N series keys. Also try typing the key # in to an ebay search. I have also used a puch to break the roll pin off to get a fork lock out of a CB77, don't know if the Ca is the same set up.
The number is
Drum Roll.
NA933
thats
NA933.
Hey I started this with bad pun LOL
Thanks
Brad
1974 CT90
1964 CA77
1964 CA77
