After the rebuild of my CB77, I am breaking in the engine, the engine is oil tight except for the cam chain tensioner.
Oil is coming out of the back of the tensioner, along the tensioner shaft.
Is there a way to cure this?
Appreciate your thoughts on this
Fred.nl
cam chain tensioner oil leakage
goudreignet
Re: cam chain tensioner oil leakage
What is your frame/emgone number?. .....lm
goudreignet wrote:After the rebuild of my CB77, I am breaking in the engine, the engine is oil tight except for the cam chain tensioner.
Fred.nl
goudreignet
O-RING DIMENTION
FRED, THE O-RING PART NUMBER FROM HONDA IS 91306-259-000 IT'S 7.4X2.4MM. ITS NO LONGER AVAILABLE IN THE US. THE CLOSEST O-RING STILL AVAILABLE IS 91307-PM7-003 IT'S 7.3X2.2MM. I DON'T THINK THATS CLOSE ENOUGH TO WORK. I'LL PUT THE CORRECT O-RING ON A HONDA CRITICAL SEARCH AND SEE WHAT COMES UP.
FAST FRED
FAST FRED
65 CL77
66 CL77
76 CB550FKR
76 CT90
66 CL77
76 CB550FKR
76 CT90
goudreignet
thanks LM, an o ring, i was on that route but could not find one in the parts manual
speaking of that, i could not cross reverance the part number you provided Fred in the parts manual from mr silver
but with the information from you guys i will get an oil tight CB77 as it should
Fred the p/n you privided is aviable at cmsnl and i have ordered one
thanks for youre offer / surch to get me one
LM and FF youre help is much apriciated and put in to good use
thanks
fred.nl
thanks
fred.nl
