5mm .90 screws
chrisnoel
5mm .90 screws
Post by chrisnoel » Tue Sep 21, 2010 12:54 pm
They sure put some odd ball screws in the Superhawk. Went all over town looking for 5mm .90 screws to replace the ones on my timing cover and starter cover. Last resort was the dealer and the had them for .30 cents each. Had quite a few gaskets in stock and abble to order as well. Who would have guessed?
chrisnoel
Dealer didn't come through.
Post by chrisnoel » Tue Sep 28, 2010 6:29 pm
Well I got some nice shiney 5mm screws from the dealer and they are .80 pitch. must have supperceded the old .90 pitch 5mm screws without realizing they are not the same. I'll have to take them back and keep looking. Turns out the screws that hold in the speedometer are .90 as well. I'll be abble to re-zink the speedo and sarter cover screws but my Timing cover screws are screwed. Pun intented.
Post by davomoto » Tue Sep 28, 2010 6:41 pm
Chris, try pming Fast Fred on the forum. He had a bunch of these, or type jis into a search, as there are suppliers for these odd pitch screws.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Don Warren
jis screws
Post by Don Warren » Fri Apr 08, 2011 11:16 pm
I know this is an older post, but did anyone ever locate any 5mm .90 screws? The fuel petcock on my CA77 needs 3... I'll tap it if I have to, but just thought I'd check
Thanks, Don
Post by e3steve » Sat Apr 09, 2011 3:24 am
I've found an inroad to a (UK) source of metric/fine screws in stainless steel. Once I've inspected the stock -- I'm in UK this month -- I'll post the link, if anyone's interested.
brewsky
Re: jis screws
Post by brewsky » Sat Apr 09, 2011 4:29 am
Don Warren wrote:I know this is an older post, but did anyone ever locate any 5mm .90 screws? The fuel petcock on my CA77 needs 3... I'll tap it if I have to, but just thought I'd check
Thanks, Don
This site says they have them, although I've not ordered any myself.
http://www.rimfire-eng.com/index.htm
chrisnoel
Fast Fred
Post by chrisnoel » Sun Apr 10, 2011 10:06 am
Ordered mine from Fast Fred as instucted and I was very happy with them.
Had to shorten a few of them but this was no problem compared to the scavenger hunt I was on to find them in the first place.
The only tap work I had to do was to chase out the threads where someone had used the wrong pitch screw on my starter cover. The longer screws that were sent actually came in handy for reinstaling the cover in this case.
The craftsman metric tap set comes with the 5mmX.90 tap that you'll need to chase out the threads.
Take an inventory of your speedo, stator and starter screws as well so you can order all that you'll need in one shot. Hopefuly Fred doesn't run out of stock.
