hi from ireland,i am starting to restore a cl77 but have a couple of problems,the bike is 1966 but the
front seat mount has been ground off along with the battery box,i want to know is the seat mount the hook type or covered in type as i have to try make it up from scratch
thanks
liam
hello and quick question
Seat Mount
liam my parts book says the seat change was at CL77-1033481. My 66 has the early seat with frame number CL77-1024184.
Fast Fred
Fast Fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
66 CL77
76 CB550FKR
76 CT90
Re: Seat Mount
FAST FRED wrote:liam my parts book says the seat change was at CL77-1033481. My 66 has the early seat with frame number CL77-1024184.
hi,my frame number is CL77-1044811,Is there anyother changes on the frame that might
identify the seat type
thanks
liam
More Clues
Looking thru the parts book another clue might be that at the same frame number the CL77's started using the rubber mounted rear fender and the switch to late style exhust pipe with welded on muffler.
Fast Fred
Fast Fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
66 CL77
76 CB550FKR
76 CT90
Re: Seat Mount
Your bike was issued with the Rubber Front Mount. ..............lm
ardri59 wrote:FAST FRED wrote:liam my parts book says the seat change was at CL77-1033481. My 66 has the early seat with frame number CL77-1024184.
thanks
liam
Unfortunately, the parts books, even the on-line fiche, show the older style seat bracket. If somebody has their seat off their late model, they might snap a picture for you and post it to this thread.
I just buttoned my bike back up yesterday or I would take a picture for you. I would think that somebody here has a bike with the seat off or a frame kicking around that they can shoot and post a pic.
Locational dimenions will be key in order for everything to properly align.
You are also going to need the rubber set setting (cushion) for the forward bracket. This piece mounts to the seat for a snug fit on the bracket. Not sure it is available as NOS. Part number is77101-273-300.
regards,
Rob
regards,
Rob
