305 Scrambler motor right cylinder popping
moondoggers
Post by moondoggers » Fri Oct 18, 2013 6:33 pm
A new issue has come up after using the LM method tune-up the right cylinder is popping.
The motor runs strong through all gears. I have finally gotten the motor to run well and I am having fun riding the bike .
Could this be a valve not seating?
Tango911
Post by Tango911 » Fri Oct 18, 2013 10:51 pm
could be that yes. check the compression on both cylinders.
65 Sears Puch 250
69 Dream 305
74 Kawi H1
78 CB750 SS
mike in idaho
Post by mike in idaho » Sun Oct 20, 2013 6:10 pm
More likely the slide is lower on the side doing the popping. Time to balance the carb settings again.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
moondoggers
Post by moondoggers » Sun Oct 20, 2013 7:36 pm
Looks like I'll need to have the top end rebuilt, I did a compression check on both sides with the right at 70 lb and left at 120 lb.
I'm out here in north central Arizona in the Chino Valley area, is anyone out there close that would do the work.
I will pull the motor.
moondoggers
Post by moondoggers » Mon Oct 21, 2013 8:51 pm
While building a set of work benches today a couple things came to my pea sized brain that might cause the low compression, the first thought was valves out of adjustment and second maybe carbon deposits on the valve seat.
There was an oil leak issue with the right cylinder last June that may tie in with the compression.
Tomorrow I adjust the valves.
Will Marvel Mystery Oil harm the the clutch, gaskets or rubber O rings if I use a little in the crankcase oil and or or gas tank to remove the carbon deposit before I pull the motor?
hondadreamca77
Marvel Oil
Post by hondadreamca77 » Thu Oct 31, 2013 4:06 pm
I currently use MMO in my 305 oil and fuel (sparingly in fuel) with no adverse affects. In fact, the gears seem to be shifting smoother since adding. Maybe someone else can chime in about seals, etc. being affected by MMO. Used it on my old 750 four for years as well. No problems.
Steve
68' 305 Dream, 75' Honda 750-four, 74' Honda CL 125, 72' Honda CA 70, 80' Honda Passport, 74' Aerimachi Harley Sprint 125, 64' Yamaha 90.
