1: The 2 screws either side of the speedo case tighten into the oval rubber/metal ring & NOT the clocks themselves, so as soon as the new cables were fitted the whole case 'lifts' at the back, pushing it down only results in it lifting again, there doesn't appear to be anything missing, so how should it be??
2: I'm making a front fender but my bike came with a cut-down version, about 15" long, so I have the cross-section to copy, but no idea as to the length.
Can someone give me the overall length along the top-centre line, the easiest way is to use thin string or cord held in place with the fingers at each end.
Using a tape-measure won't be accurate enough as it won't lay flat along the curve.
Looking at photos, i'm guesstimating around 36" or so.
Speedo & front fender
modelman
- Contact:
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
