Baffle hole position
malcolmgb
Post by malcolmgb » Fri Jul 29, 2016 5:10 pm
Could someone tell me the distance between the end of the pipe and centre of the baffle bolt hole on CL pipes please, mine had to have the ends replaced after being corroded, I assume the hole is 6.5mm for an M6 clearance.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Post by G-Man » Sat Jul 30, 2016 6:11 am
Malcolm
I'll be back in UK next week. Can check then if no-one come up with the info. I think the bolt might be M5
Re: Baffle hole position
Post by LOUD MOUSE » Sat Jul 30, 2016 6:35 am
You can measure the end of the baffle to the threaded hole.
If you have the early issue baffle its end installs flush to the end of the pipe. .............lm
malcolmgb wrote:Could someone tell me the distance between the end of the pipe and centre of the baffle bolt hole on CL pipes please, mine had to have the ends replaced after being corroded, I assume the hole is 6.5mm for an M6 clearance.
Post by LOUD MOUSE » Sat Jul 30, 2016 6:44 am
Hello G.
The parts arrived and sure are nice.
Your work if looked at by anyone who didn't know what they looked like when HONDA issued them can be assumed to be HONDA it is so good.
Thank you very much. ..............................lm
G-Man wrote:Malcolm
Post by G-Man » Sat Jul 30, 2016 6:56 am
LM
Great news! It has been a hectic week but I found a post office in Topeka on my way to a meeting.
I have just picked up a few more of the Kawasaki idler sprockets to repair the small-wheel tensioners.
Let me know how they work out for you. The screws are held with high-strength loctite.
Thanks for the kind words.
LOUD MOUSE wrote:Hello G.
G-Man wrote:Malcolm
Post by LOUD MOUSE » Sat Jul 30, 2016 7:00 am
All I need to do now is wrap engines around them. ..............lm
G-Man wrote:LM
G-Man wrote:Malcolm
Post by G-Man » Sat Jul 30, 2016 7:03 am
LM
I don't imagine there is a shortage of those!
LOUD MOUSE wrote:All I need to do now is wrap engines around them. ..............lm
G-Man wrote:LM
G-Man wrote:Malcolm
