Carb bodies
tore
Carb bodies
Post by tore » Thu Dec 12, 2024 5:07 am
Hi
Are the carb bodies same for all years & models (CB77, CB72, CL72, CL72)?
I have two left side carbs. Need to get a right side body to match up.
/T
Tim Allman
Re: Carb bodies
Post by Tim Allman » Thu Dec 12, 2024 1:36 pm
There are two styles. The earlier ones had a more rounded appearance (see https://www.nospartsnow.com/vintage-use ... 1-275-000/) than the later ones (see https://www.nospartsnow.com/nos-honda-c ... -275-000/). I think that the change happened rather early as I have never seen one.
deuce_7
Re: Carb bodies
Post by deuce_7 » Fri Dec 13, 2024 9:43 am
These carbs show up on eBay often. Here are two RH carbs:
https://www.ebay.com/itm/175536759744?
https://www.ebay.com/itm/135376001828?
Here's a pair of carburetors for parts:
https://www.ebay.com/itm/356347701725?
1967 CL77 305 Scrambler
tore
Re: Carb bodies
Post by tore » Fri Dec 13, 2024 10:45 am
Thanks!
I saw some carbs & carb bodies for sale pulled from CB72. Those will then fit CB77 with correct jettings.
Tim Allman
Re: Carb bodies
Post by Tim Allman » Fri Dec 13, 2024 1:21 pm
As far as I know they are exactly the same. That is, no re-jetting should be necessary but you might want to check that. I think the engines are the same in every way that matters.
deuce_7
Re: Carb bodies
Post by deuce_7 » Sat Dec 14, 2024 11:41 am
Here's an older Honda305.com post with good jetting info:
viewtopic.php?t=7636064
'Ol Scrambler
Re: Carb bodies
Post by 'Ol Scrambler » Tue Dec 17, 2024 7:54 pm
CB72's and CL72 used PW22 carbs with the 22 meaning the venturi is 22 mm. CB77's and CL77's used PW26 carbs with a 26mm venturi. There may be a slight problem with performance when using a PW22 on either CB77 or CL77.
