305 crank rebuild service??
Nick
Post by Nick » Tue May 27, 2025 5:17 pm
Question 1: Is there anyone out there who rebuilds 305 cranks? I'm in Hawaii and there's certainly no one here!
2. Are rods, crankpins and bearings available? From what I've read, not so much, and it seems rods that can be used need a fair amount of work Does someone offer rod kits using the modified rods?
I have access to a press and have rebuilt many singles cranks
Tanks
Tim Allman
Re: 305 crank rebuild service??
Post by Tim Allman » Wed May 28, 2025 11:15 am
A rebuild will no doubt be expensive, especially if you have to ship 20 kg of steel overseas. Perhaps replacing it would be better. I found a link to some used crank assemblies. Note that you need to get one that matches the model as the C77, CB77 and CL77 are all at least a bit different. I think that the equivalent XX72 part will work.
It's worth a better search but the problem will be knowing whether the part is serviceable. Rust is always a bad sign.
Good luck.
Nick
Post by Nick » Wed May 28, 2025 3:03 pm
Thanks, I have a complete Scrambler/Superhawk engine (not sure which yet) which I'll strip down to see if any of the crank bits or pistons are usable. However, it's also been sitting for many years....
I also have a friend in Japan who races them and will enquire if any bits are to be found there. I'll ask him if complete cranks are still available and for how much.....
Tip from Japan: For racing, use a Yamaha XS650 cam chain.
Nick
Post by Nick » Thu Jun 19, 2025 5:20 pm
Pressed the outer crank wheels off and the rods/needle bangs/pin are in excellent shape.
This is the first 305 engine I've pulled apart and I'm hugely impressed by how well designed and how robust it is.
Partzilla sells what is advertised as a OEM left-side crank bearing, just wondering if Chinese junk parts have infected the 305 world.
Tanks
Nick
Post by Nick » Thu Jun 19, 2025 5:23 pm
Pressed the outer wheels off and everything looks great just need a drive-side ball bearing. Man, that 305 is very well-designed engine!
Nick
Post by Nick » Mon Sep 29, 2025 4:37 pm
Just a note on the drive-side bearing. The bearing was very stiff, hard to turn and dirty, so I naturally assumed it needed replacing. However, because the bearing is hard to find and rather expensive I decided to try cleaning it. Surprise, surprise, after about 20 min. of flushing it with spray solvents and light oil it freed up nicely and spins like new.
