56_oval wrote:Today was my longest trip on the hawk so far covering about 60 miles. I didn't think about gas at all cause I thought I had a reserve. Well, I don't. I was on the highway and felt that lack of power from running out of fuel. I switched over to reserve, but the engine died anyway and I coasted to the side of the road. I looked in the tank and she was empty.
So, my question is what do I need to do to my petcock to get it to work? Maybe the main tube is too short or has a crack or something?
                    Rebuilt Petcock, but no Reserve?
- h305 Moderator
Re: Rebuilt Petcock, but no Reserve?
Ya had that right.
Time to remove and inspect the valve. ..........lm
56_oval wrote:DownLOUD MOUSE wrote:What angle was the fuel lever?. ..............lm
I think he's able to handle things like this. .......lm
						e3steve wrote:See, Ed? You've hurt the poor chap's feelings now! Cricketground, don't be so sensitive☺.56_oval wrote:DownLOUD MOUSE wrote:What angle was the fuel lever?. ..............lm
I stayed away so long cause I was off in a corner balling!  so,  I still have no reserve.  I inspected the brass tube that comes up out of the petcock and found no cracks.  I blew on down the tube with the petcock closed and it was tight.  I just don't understand.
Just to clarify, OFF is BACK, ON is DOWN, and RESERVE is FORWARD, right?
- h305 Moderator
I'm away from my 305 for this month or so, therefore I've no access to my parts cache; so this is just a thought: it may be that the brass tube is inserted into the wrong (reserve) orifice, thus allowing the entire content to flow from the tank in the ON position.56_oval wrote:I stayed away so long cause I was off in a corner balling! so, I still have no reserve. I inspected the brass tube that comes up out of the petcock and found no cracks. I blew on down the tube with the petcock closed and it was tight. I just don't understand.
I can't remember if the petcock orifices are identical in size; but if they are then it's entirely possible that you inadvertently inserted the tube into the wrong orifice(?).
