cl77 leaking tank questions.
sotxbill
Post by sotxbill » Sun May 10, 2009 8:24 pm
ok, if I por15 the tank, what do you do with the petcock? How do you remove it so it does not get plugged up? The tank apparently has pin holes along the bottom. Thanks, Bill
Also need gas tank bolt and nut, and complete seat bolts, nuts, and rubber assembley for this bike.
weardleyATswbellDOTnet.... is my email but replace the at and dot. thanks... Bill
britman
Post by britman » Mon May 11, 2009 4:33 am
When doing the final coating with POR 15 I used wooden dowels in the the petcock holes. They keep the sealer from leaking out and can easily be removed without disturbing the treads. BTW the POR 15 is the best product out there. Make sure you let it completely cure and it is good forever.
sotxbill
Post by sotxbill » Mon May 11, 2009 7:23 am
dowls from the inside?? do you use a long dowl or pair of needle nose piers to place the dowls?
Thanks, Bill
britman
Post by britman » Mon May 11, 2009 9:00 am
sotxbill wrote:dowls from the inside?? do you use a long dowl or pair of needle nose piers to place the dowls?
Thanks, Bill
Sorry Bill,
I always remove the petcock during the entire procedure. It is a good time to go ahead and install a rebuild kit in it while the tank is curing.
sotxbill
Post by sotxbill » Mon May 11, 2009 1:51 pm
ok. thanks for the reply.. but back to the original question. How does one remove the petcock on a cl77? Does it unscrew? or is there a nut or fitting on it?
I don't see anything in the parts manual that shows this.. Sorry to be so dense. Bill
britman
Post by britman » Mon May 11, 2009 3:53 pm
Bill,
Unscrew the bottom of the petcock. (It is the bell shaped area with the raised dome nut.) Pull out the brass strainer and o ring to expose the two phillips head screws securing the petcock to the tank base. Loosen and you are good to go.
FAST FRED
PETCOCK REMOVAL
Post by FAST FRED » Mon May 11, 2009 3:59 pm
UNSCREW FUEL STRAINER CUP FROM PETCOCK BODY, REMOVE FILTER SCREEN, PEER UP ON BOTTOM OF PETCOCK. WAHLA TWO PHILLIPS SCREEWS. CAREFULL EVERY OLD TANK I HAVE REMOVED THEM FROM REQUIRED JUST THE RIGHT COMBINATION OF WORDS BEING CHANTED OVER AND OVER.
FAST FRED
65 CL77
66 CL77
76 CB550FKR
76 CT90
