cl77 problems
cl77 problems
I just purchased a cl77 i got a really good deal i brought it home cleaned the carbs they were extremely dirty realized there was a pin hole in the float and replaced them as well as float valves. now the left carb leaks and when it first starts the idle is low once you turn the throttle it revs high and wont go back to an idle the cable is brand new as well what could this be any help appreciated thanks
Did you set the flaot levels correctly? Are the slides synced? There's a good post on here on how to set float levels without measuring. To sync slides, remove air filters and tubes, and slowly turn throttle and watch slides rise. make sure they rise at the same time. if not, ajust them with the bolt and nut on carb cap untill they rise together. It helps to have someone twisting the throttle for you.
ok i messed with the carb slides they are not in sync i havn't pulled the carbs off yet. i adjsted it but it doesn't seem to make a diffrence the right slide is halfway up before the left slide moves does this mean i need a new throttle cable. there is one liffle spot that looks like its frayed on the cable cover. the bike is running rich..
