65 CB77 idles, dies with gas
Ken184
Post by Ken184 » Sun Mar 31, 2013 3:23 pm
I've just been through the carbs, new floats, set the float height with a gauge to 22.5, sealed the tank, cleaned the petcock, new filter, etc. motor starts fine, idles fine, but as soon as i give it gas it dies. if i give it a lot of gas, it sputters and revs up, then won't idle down for longer than it should take. What do you think my problem is?
Tango911
Post by Tango911 » Sun Mar 31, 2013 4:35 pm
carb boot leaking air? is it stock pipes and air box/filter?
65 Sears Puch 250
69 Dream 305
74 Kawi H1
78 CB750 SS
Ken184
65 CB77 idles, dies
Post by Ken184 » Sun Mar 31, 2013 4:42 pm
thanks for the quick response. i don't know what you mean by "carb boot"?
I am trying to start and test without tubes and air filters attached yet. is that a problem?
Goodysnap
Post by Goodysnap » Sun Mar 31, 2013 8:04 pm
Slides in backward?
Cutouts should be to the rear.
64' CB77
65' CB160
Ken184
Post by Ken184 » Sun Mar 31, 2013 8:35 pm
kidding? of course they are. i guess i'm wondering if this is a symptom of too much air or too much gas.
Goodysnap
Post by Goodysnap » Sun Mar 31, 2013 10:24 pm
Ken184 wrote:kidding? of course they are. i guess i'm wondering if this is a symptom of too much air or too much gas.
Your the one asking for help.
I simply responded with a common issue that is often overlooked that can cause this type of symptom.
I am supposed to know this? How?
I could guess all day long.
Just trying to help.
Good luck with it.
Best Reguards,
Goody
64' CB77
65' CB160
Tango911
Post by Tango911 » Sun Mar 31, 2013 11:45 pm
its typical that an engine may not run as good with out the air filter on. its letting more air in than is needed which can bog the engine down. Also an engine thats not warmed up can run like that, after 4 or 5 minutes of running and getting her warmed up, she should respond to the throttle better. The question of the carb slides being reversed, is a common mistake. Meaning you accidently put the right slide in backward on the left carb. and vice versa.
65 Sears Puch 250
69 Dream 305
74 Kawi H1
78 CB750 SS
