Fast idle
Fast idle
I have got my 66 CA78 running but I am lost with the following situation and would appreciate some help. The air mixture screw is out 1 1/4 turns and the clip on the neddle is in the middle groove. It starts right up but idles really high and the only way to decrease the rpm's is to raise (close) the choke. It will idle fine with the slide open slightly. the more I open the slide, the higher the rpm go. It will stall with the slide completely closed.
Is the throttle slide in the right way around? Cutout toward the air filter.....
Id the flange flat with no bows? People over-tighten the bolts and this causes the flange to bow allowing air in to the joint....
You can usually flatten the flange on wet/dry paper used on plate glass. Alternatively if you have access to a lathe and sharp tools it can be trued in a lathe....
Tell us what you find...
Your right, the slide really can't go in the wrong way on the Dreams. First thing to check is that the cable isn't keeping it from closing all the way. With the throttle cable adjuster screwed all the way in, and the idle speed adjustment screw all the way out, does the slide "clunk" down in the bottom of the carb? If that checks out, you'll have to check timing, and look for fuel and air leaks.
