Petcock Spigots fell out !
dragonfly888
Post by dragonfly888 » Sat Aug 10, 2019 8:25 pm
I have a 1966 CP77 and have had some small leaking problems at the petcock (non-Honda), so, today, I decided it was time for a change.
I have a couple of clean, used early model CB77 petcocks with crossover. I chose one to install on my bike.
I first installed a complete petcock rebuild kit.
Then, I installed the petcock on my bike, turned the lever of the petcock and gas started leaking around the exit spigots.
I had already attached and secured rubber tubing from the petcock to the to the carbs.
I tried tightening the small tie-wraps which secured the rubber hose and one, then both spigots came out of the body of the petcock !!!
I didn't expect that !
Just wondering how I can re-attach the spigots to the petcock ?!? It looks like some sort of "glue" remains on one of them.
I have photos and will try to upload them.
Thanks for your help. It isn't urgent, as I have since installed another one, but I would like to save the part, if possible. Maybe someone else could use it !!!
Photos...
http://kwrcomputing.com/myphotos/cb77/2 ... 0200_a.jpg
http://kwrcomputing.com/myphotos/cb77/2 ... 0221_a.jpg
_________________
1966 CP77 305 Super Hawk
Burlington, Ontario Canada
Re: Petcock Spigots fell out !
Post by LOUD MOUSE » Sun Aug 11, 2019 9:57 am
Usually you can tap them back into the hole.
Try that as it works for me. ..............lm
dragonfly888 wrote:I have a 1966 CP77 and have had some small leaking problems at the petcock (non-Honda), so, today, I decided it was time for a change.
Photos...
DJM
Petrol tap spigots,
Post by DJM » Sun Aug 11, 2019 1:16 pm
Yes, that's worked for me too a couple of times, just tap them back in and, surprisingly, they seem to stay put.
If you're unhappy about it just add a couple of drops of Loctite or similar but don't let it get inside the tap.
