front suspension arm re-chroming
wnbasac
Post by wnbasac » Sun May 29, 2011 8:34 pm
i want to re-chrome the front suspension arm but not sure how to remove the bushings?
also handlebars it seems its a major undertaking to find a straight re-chromable bar. i've been looking for a 7/8" replacement and found several bars that fit that description but just need some clarification;
throttle slot, winker & wire holes can be made to fit and drilled via a machine shop, ok here
knurls on bottom of bars? does or don t need them?
higher rise bars need longer cables can these be custom made to fit?
just trying to re-chrome & assemble parts before repainting the bike
tks guys
brewsky
Post by brewsky » Mon May 30, 2011 5:15 am
I've used bars without knurls before on other bikes without a problem.
Some shops can make up cable sets from scratch, or Motion Pro will make them to order I believe.
May be a little pricey though.
Post by G-Man » Mon May 30, 2011 8:06 am
The fibre bushings are quite delicate but can be removed if you make up a special tool. The steel-backed rubber bushings need a heavier version of the same puller.
wnbasac
Post by wnbasac » Mon May 30, 2011 2:45 pm
ummm so if i take the arm to a machine shop they should be able to press them out and back in or pull them out and press them in
does anyone make a replacement bushing???
Post by G-Man » Mon May 30, 2011 3:28 pm
The fibre bush is very fragile so you cannot just press it out as it will collapse. My tool is a close fit on the inside of the bush and supports it as it is being pulled out. A bronze bush would be a better replacement. If you get some made then you won't have to worry about damaging the original.
I'm going to make my own bushes when I put mine back together.
wnbasac
Post by wnbasac » Wed Jun 08, 2011 10:59 pm
i say this on ebay, ( Honda C95 C92 C77 C72 C50 C100 C200 BUSH CHANGER KIT
) will it work for removing the bushings?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... _687wt_937
i'm still a little confused about the schematic showing the frt cushion breakdown
I already bought 2 ea. of the # 6 bushings and 2 ea. of items # 1,2,3,5 & 19
is that right or did i make a mistake???
ok i get bushings item # 6 but does the breakdown at the front of the picture go into the holes where the shocks bolt up?
