CB77 Hydraulic steering damper
dc2die4
Post by dc2die4 » Sat May 31, 2014 1:08 am
Hi all,
I am wondering if the hydraulic steering dampers from other models can be swapped over to a 1964 CB77. Part number 53700-237-000.
Also, what mounting bolts would I be looking for if they do swap in?
Thanks,
Khanh
Post by G-Man » Sat May 31, 2014 2:08 am
Hi Khan
Welcome to the forum. The Honda CYB race kit used the CL77 damper which was attached using two special bolts.
One was a simple stud that fits in a hole in the lower triple clamp and the other was an extended top engine hanger bolt with a cranked end.
http://www.cmsnl.com/honda-cb72-general ... ml#results
The engine hanger bolts occasionally turn up on eBay as do the CL77 steering dampers.
dc2die4
Post by dc2die4 » Sat May 31, 2014 2:31 am
Thank you G-Man. I have one more question.
There seem to be a few aftermarket bolts floating around on ebay, so I shouldn't have a problem with that, but looking at some CL77 dampers, there seems to be a bracket attached that I do not see on the CB77 parts finch. Like this one http://www.ebay.com/itm/HONDA-STEERING- ... ae&vxp=mtr
Am I right in thinking that the CB77 does not use that bracket? and the bolt(s) just mount directly through the holes? That is what I understand from reading the parts finch.
Thanks again,
Khanh
Post by G-Man » Sat May 31, 2014 3:30 am
Yes
The CB77 just uses the cranked bolt with no bracket.
