Replacement white walls
I have a all original 66 CA 77 that originally had narrow white wall tires the white wall was only around 5/8 to 3/4 inch wide. I now have blackwalls and it is not the same. I prefer not to go to the very wide versions I have found. Does anyone know of a correct narrow version available.
Thanks
Thanks
Coker is now showing them as available.
Haven't checked to see if they actually available or not.
I've seen them listed on a couple vintage parts vendors as well. (i.e. Retro Bikes)
https://www.cokertire.com/tires/styles/ ... -tire.html
I am so glad to see the tires on the site. I will have to see if they are truly available.
One more question
I prefer to replace the moderately rusty rims at the same time. Is there a source for correct rims for the bike. I am not going for prefect restored but a very good replacement.
Thanks for the tire tip and welcome
One more question
I just Ordered a pair of the firestone 5/8 white wall tires from Coker. I hope to get a set of rims by spring and then do the whole job. I did replace the wheel bearings when I put on new black walls from JC Whitney three years ago. Does anyone need a set of barely used 3.25/16 blackwalls for pretty cheap. I suppose the shipping is already too high.
