Cleaning clutch friction disks
Husker45
Post by Husker45 » Sat Jun 16, 2012 11:57 am
Picked a cb77 bottom end for parts. It looks like it had been filled with parts cleaner. The clutch friction disks look good, but I don't know if they have any residue on them. Is there a proper way to clean the friction surfaces?
Re: Cleaning clutch friction disks
Post by LOUD MOUSE » Sat Jun 16, 2012 12:06 pm
What are they made of? ................lm
Husker45 wrote:Picked a cb77 bottom end for parts. It looks like it had been filled with parts cleaner. The clutch friction disks look good, but I don't know if they have any residue on them. Is there a proper way to clean the friction surfaces?
Husker45
Post by Husker45 » Sat Jun 16, 2012 2:46 pm
Aluminum core with disk material (don't know what that is made of). Thickness of 3.75 mm. Five disks plus five metal plates. They look like the ones I have seen on this forum with part number 22201-268-020. Thanks for reponding lm.
Husker45
Post by LOUD MOUSE » Sat Jun 16, 2012 2:49 pm
Those are the ones to have.
You can clean them with parts cleaner and allow them to dry in the sun.
You can wire wheel all the steel plates. ...............lm
Husker45 wrote:Aluminum core with disk material (don't know what that is made of). Thickness of 3.75 mm. Five disks plus five metal plates. They look like the ones I have seen on this forum with part number 22201-268-020. Thanks for reponding lm.
Husker45
Husker45
Post by Husker45 » Sat Jun 16, 2012 4:18 pm
Thanks lm. I wire wheels the disks and they look great. Can you use brake cleaner to clean the friction disks?
Husker45
Post by LOUD MOUSE » Sat Jun 16, 2012 5:36 pm
I've never used it but as it does vapor quickly it may not damage the neoprene.
I use normal parts cleaner. ......lm
Husker45 wrote:Thanks lm. I wire wheels the disks and they look great. Can you use brake cleaner to clean the friction disks?
Husker45
