1967 CB77 Transmission Issue
zads
Post by zads » Sun May 15, 2016 3:54 pm
I am having an issue with my 1967 CB77 transmission. It doesn't turn over smoothly and when you add pressure to the bearing it becomes harder to turn the transmission over. The bearing also has up and down movement when it is rotated. I replaced the kickstart spindle because I thought the original had a slight bend in it and that was the problem, but it didn't fix it.
Here is a link to a video I uploaded to Youtube
https://www.youtube.com/watch?v=5tS6JiA ... e=youtu.be
What should I be checking for?
Thanks for any advice.
DianneB
Post by DianneB » Sun May 15, 2016 4:11 pm
Something is not in the proper position. The noise you hear means the gears are engaging too deeply. It almost looks like the bearing you are pressing on is the wrong O.D. 'cause it doesn't seem to fit in the boss the way it should.
zads
Post by zads » Sun May 15, 2016 4:14 pm
would you try just replacing that bearing?
Thanks for the reply.
mike in idaho
Post by mike in idaho » Sun May 15, 2016 8:44 pm
Everything looks kind of dry, did you try oiling the parts to help the gears turn on the shaft?
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
Re: 1967 CB77 Transmission Issue
Post by LOUD MOUSE » Mon May 16, 2016 10:47 am
I recommend you check the actual location of EVERY gear.
I think you have gears in the wrong location. ................lm
zads wrote:I am having an issue with my 1967 CB77 transmission. It doesn't turn over smoothly and when you add pressure to the bearing it becomes harder to turn the transmission over. The bearing also has up and down movement when it is rotated. I replaced the kickstart spindle because I thought the original had a slight bend in it and that was the problem, but it didn't fix it.
zads
Post by zads » Mon May 16, 2016 11:36 pm
I changed the location of the two gears that do not have the C clips with the wire ring and it made the transmission worse, you could not even get the kickstart spindle shaft to seat in its place. I went over the gears again, counted the teeth, everything is in the right place. I don't know what's wrong at this point.
Post by G-Man » Tue May 17, 2016 12:18 am
The clicking noise is the kickstarter pawl.
Have you looked at the selector fork on that shaft? It may be binding slightly and holding the shaft out of place.
Have you tried rotating the selector drum to get thouse gears moving into different positions along the shaft?
