Transmission shift cam positions?
DianneB
Re: switch
Post by DianneB » Mon Aug 24, 2015 6:58 pm
LOUD MOUSE wrote:Take it off and look at it.
The answer is there. ..............lm
You're a big friggin help! ;) ROFL!
Re: switch
Post by LOUD MOUSE » Mon Aug 24, 2015 7:02 pm
You can bet I am.
How do you think I learned how things work.
The answer I gave is to the point as if you don't have continuity YOU WILL REMOVE IT!. ..............lm
rrietman
Post by rrietman » Mon Aug 24, 2015 11:57 pm
D; remove the switch and lube the shit out of it. work it back and forth. reinstall. probably good to go.
Good luck
Randy
Post by G-Man » Tue Aug 25, 2015 12:42 am
The switch is operated by a slotted extension of the shift drum (cam).
As the drum rotates it turns a brass contact inside the neutral switch.
Once you have released the two screws, you can pull the switch apart to check / clean it.
DianneB wrote:Okay, checked out my transmission and it is shifting properly but, since I split the case last week, I have lost my neutral switch. Everything is working down to the connector on the neutral switch wire but the switch isn't closing.
I can't find anything in the manuals about how the neutral switch is activated and the screws holding the neutral switch in place are VERY tight and will have to be broken free with a punch.
WHAT activates the neutral switch? What could cause it to stop working? (I really don't want to open the bottom end again!)
