Front sprocket problem
~Aron~
Post by ~Aron~ » Wed May 06, 2009 8:39 pm
I got a set of sprockets and chain from rusty riders the rear sprocket fit fine and chain is right. But the front sprocket does not want to slide on the main driveshaft. My bike is a 67 CL77, are there different driveshaft or spline sizes or is it just being stubborn?
Thanks -
1967 CL77 Owner (work in progress)
Re: Front sprocket problem
Post by LOUD MOUSE » Wed May 06, 2009 8:51 pm
YOUR 1967 HAS A SHAFT WITH THE SHALLOW SPLINES AND THE ODDS ARE YA HAVE A 1962 TO 1966 SPROCKET WITH THE DEEP SPLINES. ...........lm
~Aron~ wrote:I got a set of sprockets and chain from rusty riders the rear sprocket fit fine and chain is right. But the front sprocket does not want to slide on the main driveshaft. My bike is a 67 CL77, are there different driveshaft or spline sizes or is it just being stubborn?
Thanks -
~Aron~
front sprocket
Post by ~Aron~ » Wed May 06, 2009 9:07 pm
Thanks for the quick reply LM
Is the sprocket the same across all models CA/CB/CL/77/72? just dependant on late or early model? I'm going with a 15 -34 combo.
Re: front sprocket
Post by LOUD MOUSE » Wed May 06, 2009 9:48 pm
THE RATIO WILL WORK. FOR SURE. THE CHANGE WAS MADE SOME TIME IN 1966/67. ............lm
~Aron~ wrote:Thanks for the quick reply LM
Post by davomoto » Thu May 07, 2009 2:14 pm
CAs used a 525 chain, the CB and CLs are 530, and the spline change is for all models. You'll need to find a front for the shallow splines.
~Aron~
sprocket
Post by ~Aron~ » Fri May 08, 2009 12:38 pm
Thanks for the replies, Seems the late shallow spline is a little harder to find in a 15t. And more expensive.
