CB72/77 Gearbox Bearings Clearance ?
Hi
Tried using the Message facility to ask a couple of individuals but it doesn't seem to be working so I'll ask via the Forum.
Are the 6305 & 6206 Ball Races in the gearbox meant to be STD or C3 clearance ?
I know they both have snap rings so would be 6305N but the clearance makes a difference to price from a bearing stockist.
I've looked at a collection of old bearings taken from various transmissions and none are marked "C3" but I don't know if clearance is normally marked.
thanks in advance
Phil
thanks in advance
Phil
Standard or 'normal' clearance is around C2.5 or CN. The tightest clearance is C0 but not usually deployed where heat is involved or where there are interference fits for inner or outer races. C0 would be used where very precise alignment is required.
As the radial clearance increases, so does the axial clearance and the bearing is also able to resist more axial load such as when helical gears are supported.
The difference between 'standard' and C3 is minimal.
The lineup of bearing play is a little strange, from tight to loose: C1 C2 C0 C3 C4 C5
C1 is the most tight bearing, C5 has the most play. I use C3 bearings in engines because of the tolerances and the heat / cold cycles in engines. The price difference between C0 and C3 is minimal,
