Background:
1965 CL72 with a 305 in it. Bought it from a guy who said it ran great, but the clutch cable just broke. Replaced the cable and it ran pretty decent. It would creep some when you would pull the clutch handle and have it in gear. Now the when I pull the clutch handle and drop it into gear it will immediately take off, or in my case stall since I know this is going to happen.
1st question:
The clutch plates were stuck a bit but not bad, and don't look all that bad. I think I am missing a circlip somewhere. I don't understand how pushing the rod from the right side will cause the plates to separate.
When I remove the 4 bolts and springs on the clutch basket, the friction plates will slide out. Is there something that is supposed to hold them together? I found this pic from an ebay auction. Can someone please explain the function of the circlip?
2nd question:
What they heck is this?
Thanks for your help!
CB
