Removed Right Side Cover
catterar
Post by catterar » Sat Sep 29, 2012 4:54 pm
Spent two days spraying the case screws with PB Blaster, still could not get them to budge. Drilled the heads off and this is what I found.
Dirty by catterar, on Flickr
Several hour with mineral spirits and a parts cleaning brush, a plastic spoon and a toothbursh and this is where I am now
Clean by catterar, on Flickr
What should I use to lubricate the clutch lifter and the kick starter shaft? I'm thinking white lithium grease.
Thanks,
Bob
Mike Mullins
re:
Post by Mike Mullins » Sat Sep 29, 2012 8:45 pm
I have always used bearing or all purpose grease. I feel its heavier and stays put longer.
Just get a can at the auto store or Wally World. Not expensive, and always useful.
Mikeyrx
66 CB 77
76 BMW R75/6
99 GL 1500 trike
75 & 79 XS 650's
48lesco
Post by 48lesco » Sat Sep 29, 2012 9:50 pm
I would recommend disassembling and cleaning the clutch lifter and kick shaft/spring assemblies in the right side cover and packing with moly grease. Send some cable lube down the clutch cable too while you have it apart. Make sure the ball bearing is in the lifter assy. I like to put a little moly grease on the sprocket and splines too.
-48
jensey
Post by jensey » Sun Sep 30, 2012 4:44 am
all purpose grease
No offense, but all purpose means "can do everything, not the best for anything"
Kick starter with lithium bases grease, clutch lifter with engine oil (no grease).
Clutch lifter mechanism with lithium based oil, but a better option is molykote (lithium based grease with graphite).
If you make a mixture with 1/2 part engine oil and 1/2 part molykote, you can use this for cables.
It's wise to take off the front sprocket and clean the splines of the main shaft and inner part of the sprocket. Then take a chain grease (the one you have to warm up before making it soft) and apply to the splines before you assemble the sprocket.
Snakeoil
Post by Snakeoil » Sun Sep 30, 2012 10:12 am
I see you got all the screws out. Congrats on that.
regards,
Rob
