kick start swing arm foot pedal disassembly question
Steverino
Post by Steverino » Mon Nov 02, 2015 2:54 am
Can anyone tell me how to separate the kickstarter swingarm from the kickstarter pedal? I see that the individual pieces are sold separately so I know it can be done. Thank You
Steve
Post by G-Man » Mon Nov 02, 2015 5:39 am
You need to make some kind of tool to push on the pedal where the circlip seats. Once you get the circlip out the pedal will come off.
Re: kick start swing arm foot pedal disassembly question
Post by LOUD MOUSE » Mon Nov 02, 2015 8:13 am
Do you really need to take that apart?
Not the easiest thing to take apart then reassemble.
I made a tool with 1 inch angle iron with hole 1/8 inch oversize the kick starter knuckle washer, 3 inch bolt.
I place the KS lever in a vise and use the tool to push the washer down and then remove the clip.
If I get a chance I'll send a pic. ................lm
Steverino wrote:Can anyone tell me how to separate the kickstarter swingarm from the kickstarter pedal? I see that the individual pieces are sold separately so I know it can be done. Thank You
Steve
Steverino
Post by Steverino » Mon Nov 02, 2015 10:35 am
The only reason I want to take it apart is the plating on the swingarm is good but it is gone on the pedal. If I could put an acceptable original type of finish on the pedal that would solve the problem.
S
Post by LOUD MOUSE » Mon Nov 02, 2015 10:45 am
Have you considered Aluminum Paint?. .........lm
Steverino wrote:The only reason I want to take it apart is the plating on the swingarm is good but it is gone on the pedal. If I could put an acceptable original type of finish on the pedal that would solve the problem.
S
Steverino
Post by Steverino » Mon Nov 02, 2015 1:19 pm
Thanks LM
Now I know what I'm going to do this afternoon. I'm waiting for my new snap rings to show up.
Steve
pemdoc65
Post by pemdoc65 » Wed Mar 09, 2016 8:27 pm
I have used a brake spring tool that is used to compress the small coil spring in automotive drum brakes to remove the circlip on the kickstarter arm. I clamp the kickstart arm in a vice so I can press downward, then have my son remove the clip with a magnet.
