Acorn nut for cylinder studs?
PrisonCityMatt
Post by PrisonCityMatt » Sat Aug 04, 2012 3:38 pm
Something standard found at a fastener store? I believe theyre 8mm but Im wondering if I need to get a specific kind like aircraft or something. Thanks!
Re: Acorn nut for cylinder studs?
Post by LOUD MOUSE » Sat Aug 04, 2012 4:13 pm
The HONDA ones are a deep threaded nut. ...........lm
PrisonCityMatt wrote:Something standard found at a fastener store? I believe theyre 8mm but Im wondering if I need to get a specific kind like aircraft or something. Thanks!
rrietman
Post by rrietman » Sat Aug 04, 2012 11:58 pm
I think they are a grade 8 also, or some kind of heat hardened. I have had no luck trying to zinc plate them. the originals are as common as dirt, how many do you need?
Randy
Post by LOUD MOUSE » Sun Aug 05, 2012 1:32 am
I have mine cad plated to renew the finish. ...........lm
rrietman wrote:I think they are a grade 8 also, or some kind of heat hardened. I have had no luck trying to zinc plate them. the originals are as common as dirt, how many do you need?
Randy
