I run the electronic ignition on my 1962 CB77 - 21k miles. I set it up years ago, but recently, I went back and checked the timing.
It seems that all is not exactly as it should be: The left side gets to full advance, but the right side is a bit retarded.
Also, there seems to be some play in the metal sensor attached to the points cam. I can turn it back and forth a little with the engine at rest, which to me indicates there is some slop in the points cam.
I assume this has something to do with a worn advance unit, correct?
Any ideas? fixes?
Thanks,
nander
E ignition and timing problems
Re: E ignition and timing problemsSprings. ...........lm
Ya may be able to get to that area and replace the springs from the top.
Could be only one spring is bad.............lm
