Replacement Metal Cap/Nut for CB72 Coil ?
Phil-UK
Post by Phil-UK » Sun May 01, 2011 5:58 pm
Hi
For CB72/77s - has anyone found an alternative replacement for the thin metal nut/cap that screws onto the ignition coil and holds the HT lead in ?
I have a pair of coils that seem OK but one has no nut ( gland nut ? ) and on the other one it has almost completely corroded through. Will anything from a later one fit .. are they the same thread on all Japanese ignition coils that have removable HT leads ?
thanks
Phil
Crackleport
Post by Crackleport » Thu Jun 14, 2012 11:59 am
I used the plastic ones from Wemoto. See their description below.
Ignition Coil Cap Set to fit 713788 713790 713791 713793
They work fine. Didn't want to spend a lifetime looking for the original metal ones.....
Phil-UK
Post by Phil-UK » Thu Jun 14, 2012 1:38 pm
Thanks ... they are only about 15 miles away so I'll pick some up once the water subsides !
Phil
