correct Tappet clearance for 65 CA77 dream
correct Tappet clearance for 65 CA77 dreamha guys i need the correct clearance adjustment for 65 CA77.i have a service manual on order not here yet thxs for the info.
Re: correct Tappet clearance for 65 CA77 dreamALL-----------.004. .....................lm
correct Tappet clearance for 65 CA77 dreamthank you LOUD MOUSE thats great.i'm going to adjust the points & timing the way you explaned it the motor doesn't smoke sooo after i set it up like you do she should run like a raped ape.
correct Tappet clearance for 65 CA77 dreamLOUD MOUSE that is .004mm ?
Re: correct Tappet clearance for 65 CA77 dreamMM doesn't count that way.
.004 TH. .....................lm
correct Tappet clearance for 65 CA77 dreami learned something new everyday that makes it a great thxs.
