crankshaft
teekay
crankshaft
Post by teekay » Sat Jun 19, 2010 7:23 pm
What is the special tool to remove the rotor on the right side of the crankshaft on a CB77?
teazer
Post by teazer » Sun Jun 20, 2010 3:14 am
To remove the alternaotor rotor use the rear axle and to remove the oil slinger nut cut down a suitable socket after knocking back the locking tab.
Mike Mullins
rotor removal
Post by Mike Mullins » Sun Jun 20, 2010 7:04 am
I posted this sometime back. I dont think there's a bolt on the bike that will work
Mikeyrx
I posted the same question early November, and then found the answer. ( The post is listed under "rotor removal", and I think the date is Nov 2 or thereabouts. You need a 16mm bolt with a 1.5 mm. thread pitch. Needs to be about 1-1/2 in long ( about 38 mm. more or less. ) I found that this size is not normally stocked anywhere. I got mine at Sanders Indiana Hardware in Valparaiso, IN. They are a fastener wholesaler, and I went to grade school and high school with all the Sanders kids. I could not find ANY other bolt on my CB 77 that would work for pulling the rotor.
Mike Mullins (mikeyrx)
66 CB 77
76 BMW R75/6
99 GL 1500 trike
75 & 79 XS 650's
jensen
Post by jensen » Sun Jun 20, 2010 11:01 am
No, you will find the axle on early dreams,
Post by davomoto » Sun Jun 20, 2010 3:56 pm
Motion Pro sells a puller for around $10. motionpro.com
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Scram64
crankshaft
Post by Scram64 » Mon Jun 21, 2010 2:20 pm
davomoto wrote:Motion Pro sells a puller for around $10. motionpro.com
Try this site address http://www.motionpro.com/motorcycle/partno/08-0027
Scram64
rustywrench
rotor remover
Post by rustywrench » Mon Jun 21, 2010 4:23 pm
I once bought a chain breaker from Harbor Freight and found that the large bolt from that tool worked for removing the rotor. WOW!!!!!! Two tools for the price of one. RW
