intermix
crank
hi gordon,this is why i need to know what crank the ca77 has because at the moment i only have the one in the seized ca77 but i might be able to buy a cb72 crank to fit the cb72 crankcases i have so need to know as soon as possible,regards john
John,
I'm a little confused on what you are asking for with the info you have given. You start off saying you have a CB with a CL engine and later you give a Engine # of a CA. The CA's as far as I know are all 360 degree and do not have a tach drive off the left side of the cam and have one carb. Some CL's are Type 2 which means they have 360 degree cranks and the Type 1 are later and have 180 degree cranks but neither has the oil hole for the electric starter and the cams on either due not have the tach drive. The CB's either the Type 2 or Type 1 both have the tach drive and the crank with the oil hole for the electric starter. I hope this helps. Cliff
crank
hi clif,what i bought last week was a rolling cb72 frame which came with a ca77e 1008**seized engine and a set of empty cb72 crankcases a cb72 barrel and a bare cb72 cylinder head what i hoped to do was take the internals from the ca77 and fit them into the cb72cases or would it be easier to buy the cb72 bottom half i have been offered if more expensive,regards john.
head
hi cliff,no the head is completely bare,
ok
hi cliff, that is what i wanted someone to say,im not very good at explaining my problems so when reading my questions of which there will be many i presume please bear with me thanks for your help,regards john.
