CB77 Gastank
Hahnda
Post by Hahnda » Sun May 21, 2017 12:36 pm
I believe that petcock is for a CB350. It should work but may not be totally correct.
DJM
Post by DJM » Sun May 21, 2017 4:49 pm
The crossover / balance tube was deleted on late CL models and a Honda Bulletin issued in May 67 listed revised part numbers for both the tank and the fuel tap body.
I haven't found a similar Parts Bulletin for the CB models but the fuel tap body on CB models was changed at CB77 1052488, very late in the production run. I believe this change was made for the same reason, IE deletion of the crossover tube. Honda decided was 'not necessary and therefore deleted.'
On a personal note I beg to differ with Honda on this one, I recently ran out of gas on my CB77 (which has the balance tube blanked off to simplify fuel tank removal.) There was clearly gas in the right hand half of the tank but none was reaching the carbs, luckily I was at the top of a hill when the bike died, the petrol station was at the bottom!
fourristi
Post by fourristi » Mon May 22, 2017 9:29 am
Hello
Seems to me you are getting a little bit mad!
In no way I didn`d critisize your answer,just wrote like it is. CB77 gastank and a petcock from Kanada sold to me as a CB77 part!!!
Regards Achim
fourristi
Post by fourristi » Mon May 22, 2017 9:43 am
Hello
So when I read all this.it may be possible that there are gastank`s whit only one outlet.
When I strippet the tank from paint I could not find any sing for fixing.The bottom is one plane peace.
Achim
pemdoc65
Post by pemdoc65 » Mon May 22, 2017 6:30 pm
I saw a CB77 tank without the crossover tube only once on an ebay auction several years ago, but none since. That petcock looks like the one that Sirius Consolidated lists as a CB77 unit. It is identical to my CB350 unit. It should work fine if you don't have a crossover tube on the tank, except that the outlets are on the left side of the body instead of the right like a stock CB77 petcock. This may affect the routing of your fuel lines a bit.
fourristi
Post by fourristi » Thu May 25, 2017 3:27 am
Hello
Thanks to all of you!!
Your reply`s where very helpful!!!!!!
Regards Achim.
